installed.png problem ??
Thread began 2/06/2012 8:57 pm by lr_leal239405 | Last modified 2/07/2012 11:55 am by lr_leal239405 | 1625 views | 4 replies |
lr_leal239405
What in the world is installed.png? I did some research and it looks like it's a php file in disguise. It looks like mine was corrupt because it was 0kb. I found another thread where one of the techs provided it for download and I downloaded it and replaced mine. At first the page wouldn't even come up but now it comes up with the error:
Notice: Undefined variable: wa_settings in D:\wwwroot\betelife.org\www\Images\installed.png on line 9
What do I do now?
Thanks you.
craig435405
Think my fault is the same file
Warning: require_once(../images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /home/allel465/public_html/mygarage/WA_Globals/WA_Globals.php on line 60
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.png' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/allel465/public_html/mygarage/WA_Globals/WA_Globals.php on line 60
gruant2000381341
I'm only saying what it is because you asked, it's a license checking script renamed to a png.
I think you may have found a version of the installed.png file from a different solution pack, here is the correct one for power CMS Builder.
installed.png.zip
lr_leal239405
thanks. that worked.
lr_leal239405
This post has been deleted.
