Looping Horizontally
Thread began 2/06/2012 8:13 am by deanmale2001272549 | Last modified 9/07/2012 8:48 am by Jason Byrnes | 3005 views | 7 replies |
deanmale2001272549
Would appreciate a definitive, straight forward answer on Horizontal Looping. All's I want to do is have 3 rows, 8 columns for product display.
Is it Repeat Selection, Repeat Region, Repeating Table, something different, a combination of the above??? I've been through them all for my recordset, none work. Thanks.
use the repeating table behavior.
this will add a blank table cell to the page that will use the recordset to repeat as many columns and rows as you set in the wizard, you will need to populate the blank cell with the data to display using the bindings panel.
deanmale2001272549
No Repeat
I set up repeating table behavior for 3 row, 11 column.
Insert> Webassist> Dataassist> Repeating Table
Does not repeat.
No_Repeat.zip
stephen287384
Same Problem
Was this resolved? If so, please post resolution as i am having same issue.
Seems to be an issue with inserting the repeating table into a spry tabbed panel. If i create a new blank page with nothing else on it then insert the repeating table it works, but when inserting it into a tabbed panel in my current page it does not work.
can you end a copy of the page in a zip archive please. Also, if it is a live page, it would help to see it in the browser, do you have a link.
stephen287384
I have attached 2 files, working page script and broken page script. The broken script is exactly how data assist inserted it into the tabbed panel. As you can see the <table></table> tags are in different places for some reason which may be the problem.
I followed the same process in both pages ie: insert>webassist>data assist>repeating table
brokenCode.txt
workingCode.txt
