Error in Results Page
Thread begun 2/03/2012 8:35 am by salaroche | Last modified 2/06/2012 2:57 am by Ian S | 1611 views | 3 replies |
salaroche
Hi:
The pages I generated using Data Assist's Wizard were working fine for a while, but I guess I must have made an error while customizing those pages and now I'm getting an error message saying:
Parse error: syntax error, unexpected ';' in C:\xampp\htdocs\DjibOx.com\djibResults.php on line 109
Attached please find the Results and the Search pages in question.
Any suggestions?
Thank you for your attention
salaroche
Jason:
Thanks for creating the ticket. However, I just went ahead and re-created the whole Search sequence and up to know it's working fine. Thanks.
Ian S
I've come across this error before but only if my original DW recordset has a parameter in it.
Sometimes when applying the Data Assist Search behaviour you lose the data type code of the end of the parameter (i.e "int" or "text") and so the page throws a wobbly.
Sometimes opening the recordset and closing it again fixes the problem, or you can just hand code the data type back into the recordset parameter.
Cheers
Ian
