Create new regions after installing
Thread begun 2/03/2012 3:48 am by Hamburg Webdesign | Last modified 2/03/2012 8:29 am by Hamburg Webdesign | 2310 views | 5 replies |
Hamburg Webdesign
Hello,
is it possible to create or delete some regions after installing Site Sculptor and to edit the new ones within the CMS of SS?
I created a form with CSS Form in an exsisting contact site. Worked fine!!! I deleted one region in this site. When I select the site there are shown new editable regions, but they are not shown on the site??!!
Is it about that SS works with virtual websites? I read about it in the forum, but I didn´t really understand.
And now my customer is asking me, if it would be possible to create some more regions within one site ... ;-(. He wanted to have a box with three areas within a region that is already been created.
Glad to hear from you.
Best regards,
Mo
P.S: this is the idea about the code that I had:
  <div class="Boxwrapper">
<div class='cssLO Boxwrapper_wrapper_layout'>
<div class='wrapper cssLI Boxwrapper_wrapper_design'>
<div class='cssLO Boxwrapper_box1_layout'>
<div class='box1 cssLI Boxwrapper_box1_design'><!-- box1 Content Starts Here --><?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Leistungen' , 'Box1'); ?><!-- box1 Content Ends Here -->
</div>
</div>
<div class='cssLO Boxwrapper_box2_layout'>
<div class='box2 cssLI Boxwrapper_box2_design'><!-- box2 Content Starts Here --><?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Leistungen' , 'Box2'); ?><!-- box2 Content Ends Here -->
</div>
</div>
<div class='cssLO Boxwrapper_box3_layout'>
<div class='box3 cssLI Boxwrapper_box3_design'><!-- box3 Content Starts Here --><?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Leistungen' , 'Box3'); ?><!-- box3 Content Ends Here -->
</div>
</div>
<div class='cssLClearC'></div>
</div>
</div>
<div class="cssLClearL"></div>
<!-- #Boxwrapper (CSSLayouts End) -->
Hamburg Webdesign
I found this link:
showpost.php?p=95718&postcount=2
Must be the right instructions but pooo, I don´t understand really what to do.
What link is meant?
  at the top of the page, right under the "Choose the content area you wish to edit below" is a "View This page" link
Click that link, and you will see in the address bar that there is a querystring variable:
template.php?Template=3
The picture of the attachment doesn´t show such a possibility. Only if I click "Edit" in one selected region. That´s the first problem.
Any help? :rolleyes:
well, that link is for the power CMS Solution pack, the CMS of Site Sculptor is based on the power cms, but is slightly limited.
with site sculptor, you cannot add editable regions or pages after the site has been created.
you would need to recreate the site to add these regions.
while running the site sculptor wizard, you can select pages to be based on a template to get the page template options from the link you are referring to
Hamburg Webdesign
Jason, thanks a lot.
but I understand it right, that I only can select one template? And the template could have two different designs (one for the home page and one for the content page)?
I think, that I want too much. So better I do it manually like always.
yes, that is correct.
Hamburg Webdesign
Ok Sir :).
Thanks!
