No Upload?
Thread began 2/01/2012 6:59 am by Remco209061 | Last modified 2/01/2012 1:18 pm by Jason Byrnes | 1861 views | 7 replies |
Remco209061
No Upload?
Hello
can you please help me because I don't understand what's going wrong I have an simple file upload but it wont work there is no upload and there is no input into the database. I used it before and never had problems. I use the latest update.
The input-field before I created the file-field worked fine.
grts Remco
Insert.txt
for a file to upload, the forms encoding type needs to be set to multipart/form-data.
change the form tag:
<form  action="Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<form  action="Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
Remco209061
Ok thanks, but why does it not go automatic? I was searching several ours for the problem.
if you use the insert -> Forms -> File Field it will set it automatically.
Remco209061
I use Data-Assist Wizard this created the form-field or is the combination not perfect?
while the data assist wizard can add file fields to the form, it does not add any file upload functionality so the forms encoding type will not be edited.
select the form tag from the tag selector and change the encoding type to multi part form data.
Remco209061
right, but is it someting new? I am using it several years but this never happend I know there are a lot of problems and I made a list of them so I can work faster but this is a new one.
no, this is not new. it has always been this way.
