File Manipulation Uploads in UE
Thread begun 2/01/2012 6:05 am by gary.brett434358 | Last modified 2/02/2012 7:30 am by gary.brett434358 | 3012 views | 8 replies |
gary.brett434358
Hi, using Dynamic Suite I wanted to add a file upload to both my insert & update pages. Do I need to store images in a db table? Currently I have tblcases that stores new cases, at the end of the insert/update pages I want to add the upload feature. Do I need to create another table and link it to tblcases by CaseID to store all documents?
So far I have added the upload behaviour to an insert form in testing but the file never uploads, I note the path becomes c:\fakepath\filename.txt after selecting the file, using IE & Chrome?
Code inserted by DA:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "CaseDocuments/",
'FileName' => "[FileName]_[Increment]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "doc_upload", "0", "", "false", $WA_UploadResult1_Params);
Not sure if I actually have DFP or not, I can only get this wizard through Insert | WebAssist | File Manipulation | Upload
Thanks.
the file manipulation behaviors are the same as the DFP behaviors.
the uploaded files will be stored on the server, you should be storing the uploaded file name in the database.
"Do I need to create another table and link it to tblcases by CaseID to store all documents?"
yes, if you are creating a one to many relationship (one case to many documents) the file names should be stored in a separate table.
send a copy of the insert page so i can examine the full page code to determine why the upload is failing.
gary.brett434358
Hi Jason,
I hadn't included any database tables or fields just followed the tutorials on basic usage.
I have attached the basic insert page which i just wanted to have docs stored in '/CaseDocuments' folder with 'CaseID+ContactID+Increment' as filename. Woudl I use session values for that?
Are there any details tutorials explaining it all?
Cheers
first, for the upload to work, the form encoding type needs to be changed:
change:
<form method="POST" name="WADAInsertForm" id="WADAInsertForm" class="mainForm">
<form method="POST" enctype="multipart/form-data" name="WADAInsertForm" class="mainForm" id="WADAInsertForm">
as for using the client and case id in the uploaded filer name, this will be tricky.
first, the file upload code will need to come after the insert record code.
the case ID will come from the tblcases_CaseID session created by the insert behavior, it looks like you have a form element for the contact, so you will need to use that binding. This is not a supported feature and will take some custom coding.
gary.brett434358
Hi Jason, what are the normal naming procedures with DFP, does it simply upload the file with the original image name as standard?
I need to try and understand how I can 'bind' any uploads with their relevant cases, if its not supported no worries. I just thought I could append a session value such as CaseID onto originalfilename [001_samplefile.pdf]. Only the case owner would then see the documents.
Thanks again.
binding the case ID to the file name would not make it so only the case owner could see it.
for that to work, you would store the file name as is, into a new table and also store the case owners ID.
you could then create a recordset to show all case files and filter it on the logged in users session to return the files for that user.
gary.brett434358
Sorry Jason, may have confused things a touch. What I meant was if the upload is linked to the CaseID then each time the case owner viewed or updated the case they would have access to any uploaded files relating to that case.
Am I correct in creating a new recordset based on tblUploads, then during DFP wizard choosing this recordset and filename field for the destination folder? I guess not as that doesnt upload any filename to the table, if I select an actual folder it does upload but then how do I insert filename & CaseID into the table to link?
<?php echo $row_rsFileUpload['FileName']; ?>
Are there any WA helpfiles on methods to us DFP to insert files to tables, the wizard seems to only make a standard upload from what I can see. I hate to keep bothering you but have no guidance on how the extensions operate except using the forums.
the problem here is that you are trying to figure out 2 things at the same time:
1) how to create a relational database for your needs
2) how to use data assist to manage that database.
and you are approaching the problem from the data assist angle first, that's kind of putting the cart before the horse. you need to figure out your database structure first, before you begin trying to create the pages with data assist. If you don't figure how the database is going to work, it's going to make figuring out data assist impossible.
so, you have cases and files for those cases. you will need to use 2 tables for this
cases:
caseID - primary key
casename
etc...
caseFiles
caseFileID - primary key
caseFileCaseID - relates to cases.caseID
caseFileFileName - gets the name of the uploaded file
your insert form should insert the case data to the case table, then in another insert behavior, it can insert the case ID using the session that is created from the first insert to the files table and use the Server File Name binding from the WA Uploaded Files binding group to insert the file name to the files table.
gary.brett434358
Hi Jason, yes I managed to finally work it out early this morning by playing around. What threw me was DFP doesn't create the insert behaviour, its little things like that which keep me on one page for days!
Now I need to work out how to retrieve the doc in the detail pages, another head scratcher for me I am sure!
