Error with Connections File on install
Thread began 1/31/2012 6:42 pm by elevy388997 | Last modified 2/08/2012 2:55 pm by elevy388997 | 1614 views | 5 replies |
elevy388997Beta Tester
I searched other posts and found that sometimes the connections folder and the path don't quite match up but I checked and the folder IS getting created, and install3.php is pointing to it correctly. The only thing I am wondering is when I goto the website without "www" i don't get the install wizard. I HAVE to add the "www" beforehand to access it and after I input the username and password I get:
Warning: require_once(PowerCMSConnection.php) [function.require-once]: failed to open stream: No such file or directory in /home/daryecko/public_html/install/3.php on line 3
Fatal error: require_once() [function.require]: Failed opening required 'www.cbpower.net/Connections/PowerCMSConnection.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/daryecko/public_html/install/3.php on line 3
Again I checked the other posts and thought from what I read that I would either not have the connections folder being made, or it is pathed to the wrong file... but they don't seem to be the case.
I am still having problems with this. I installed the new design extender and the problem is slightly different.
At first I got the same error with the connection file on line 3. So I deleted the connections folder from the live site. Then I typed in the domain and get this error:
Warning: require_once(../Connections/PowerCMSConnection.php) [function.require-once]: failed to open stream: No such file or directory in /home/daryecko/public_html/install_cms/logininfo.php on line 16
Fatal error: require_once() [function.require]: Failed opening required '../Connections/PowerCMSConnection.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/daryecko/public_html/install_cms/logininfo.php on line 16
It seems to not be creating the connections folder anymore. I really need this looked into.
Also, after creating the new site with the "new extension" my index.php page only has this in the code - <?php header('Location: admin_cms/users_login.php'); ?>
update the support ticket that was created for you with this info and we will look into the problem.
Maybe this has something to do with it... Before I upload the files to the server, I preview with local files so make sure the design is showing properly. Could that change the code anywhere before I upload it live?
(I also noticed some files that had to do with the beatles... /files/ What is that about?)
For future reference. The problem was that my password had a $ in it.
