File Upload and Update not inserted into database, is uploaded to directory
Thread began 1/31/2012 9:53 am by toni272059 | Last modified 1/31/2012 2:48 pm by toni272059 | 2644 views | 6 replies |
toni272059
I have added File Upload to DataAssist Upload and Update pages. Forms are working with the database -- I have tested with Updating text content.
When I try to upload an image file in the Update page the image form field goes blank and the page is not redirected.
However the image is being uploaded into the correct directory but is not being added to the database and not showing on the Detail page (obviously).
I have run through Adding DFP to DA Insert and Upload pages twice and no success.
I am attaching ZIP with the DataAssist generated pages and the helperphp.php file
Note: Images I inserted manually into the database do appear in the Detail page image area. See attached JPEG
Thanks!
DFP.zip
it sounds like an error is occurring, but you have display errors disabled.
change:
ini_set('display_errors','0');
so we can see any errors that are occurring, this will help us determine what the problem is.
toni272059
I found the error display code on another forum post!
Anyway, changed and the following error came up when I tried to Update an existing Product by uploading an image.
screen-grab-update.jpg attached.
The new images have been uploaded to the directory
ERROR MESSAGES
Notice: Undefined index: WA_UploadResult1 in /Users/tonimills/Sites/Boomerang_Needleworks/bn_admin/adminUpdate.php on line 114
Warning: Cannot modify header information - headers already sent by (output started at /Users/tonimills/Sites/Boomerang_Needleworks/bn_admin/adminUpdate.php:71) in /Users/tonimills/Sites/Boomerang_Needleworks/bn_admin/adminUpdate.php on line 140
CODE FROM LINE 114
$WA_fieldValuesStr = "".((isset($_POST["group_id"]))?$_POST["group_id"]:"") ."" . "|" . "".((isset($_POST["product_number"]))?$_POST["product_number"]:"") ."" . "|" . "".((isset($_POST["item_name"]))?$_POST["item_name"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["item_desc"]))?$_POST["item_desc"]:"") ."" . "|" . "".((isset($_POST["item_size"]))?$_POST["item_size"]:"") ."" . "|" . "".((isset($_POST["item_price"]))?$_POST["item_price"]:"") ."";
CODE FROM LINE 140
Insert New Product
I tried to Insert new product information and text, same problem/error messages. Screen grab attached. I also tried to Insert a new product without including an image. Same problem. (Images are not required by the database.)
Attachments: screen-grab-insert-with-image.jpg
this code:
is referring to an upload object that does not exist.
this code:
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../images/",
'FileName' => "[FileName]_large",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "500",
'ResizeHeight' => "",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult2_1 End
// WA_UploadResult2_2 Start
$WA_UploadResult2_Params["WA_UploadResult2_2"] = array(
'FileName' => "[FileName]_small",
'DefaultFileName' => "".((isset($_POST["item_photo"]))?$_POST["item_photo"]:"")  ."",
'ResizeType' => "4",
'ResizeWidth' => "270",
'ResizeHeight' => "270",
// WA_UploadResult2_2 End
// WA_UploadResult2 Params End
is creating the $WA_DFP_UploadStatus["WA_UploadResult2"] object, but the insert and update behaviors are referring to the $WA_DFP_UploadStatus["WA_UploadResult1"] object.
did you add 2 upload behaviors to the page, then remove one? that's about the only way I could see that happening.
toni272059
Yes, I went thru the setup instructions twice and then deleted the first. I see I missed one setting that needed changing from 1 to 2. $WA_DFP_UploadStatus["WA_UploadResult2"]
I have now done a global search on the Update and Insert pages for UploadResult and made sure all are UploadResult2
Now I am getting just one error message when I try to Update a record by uploading an image. update-page-error.jpg
Line 140
The image is uploading into the directory. However the jpeg file name disappears from the form field when I click Update button and the page does not redirect. However the image does now appear on the Detail page though in very poor quality considering it did not need to be resized. detail-page.jpg
the error means there is output between php tags.
see the following page for details:
showthread.php?t=19285
in the file upload behavior, you have left the default file setting for the main image blank, only the resized image has a default file setting. you need to bind the main images default file to the hidden form element.
toni272059
That was it, empty lines between closing and opening php tags!!!!!
Also, thanks for tip on image settings.
Now to continue and see what my next challenge will be....
