Australia selected but US states showing
Thread began 1/30/2012 9:36 pm by studio366170 | Last modified 2/06/2012 11:37 am by Jason Byrnes | 2225 views | 23 replies |
studio366170
Hi, how do I make the Australian states show up when Australia is selected.... thanks!
on the webassist/plugins/side_menu/nested_accordion/sidemenu.php page, find the following line:
<script type="text/javascript" src="functions.js"></script>
and change it to:
<script type="text/javascript" src="../accordion/js/accordion.js"></script>
studio366170
Thanks Jason. I tried that but now get a weird message 'tba' where the states should be ? What has gone wrong? (screenshot attached)
send a link to your site please.
studio366170
onceonneveroff.com.au
studio366170
...also, is there any way to get the checkout page to display as two pages? Thanks.
you have edited the state form element o the checkout page to be a text box instead of a select list. For it to work properly and show the australian states, it needs to be a select list like it was originally.
the original checkout form uses a select list for the states and is populated by a recordset. by changing it to a text box, you have broken the functionality that populates the list with the appropriate states for the selected country. you will need to revert back to the original checkout page.
No, power store does not support using a two page checkout form.
studio366170
I am not sure what you mean, as I didn't do anything except add the code you said - or did I add it to the wrong place?
How do I get it back to being what you say it needs to be, as I am copying and pasting the code you recommend (however may have put it in the wrong place?)
If you can post the code for that page in total, as it needs to be that may be the quickest way to resolve this.
Or is the checkbox thing something that happens from within the database itself?
Thank you,
Simone
did you edit the ps4_regions table in the data base? that table is used to populate the states list, if that table does not contain any recordset, the states list will get replaced by a text box.
attached is an sql script to recreate the ps4_regions table. see the "How to import a MySQL (.SQL) file to your database " tutorial on the learning resources page for details on using the script:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
ps4_indexes.sql.zip
studio366170
Yes, unfortunately I went in to the database and deleted the countries she did not want to have on her site.... and must have accidentally deleted the regions....
Thank you for the sql file and the link - I will get onto this today and hopefully fix it!
Best wishes,
Simone
