Different looking editor to HTML editor!!
Thread began 1/30/2012 5:49 pm by mrs | Last modified 2/01/2012 7:30 am by Jason Byrnes | 1837 views | 6 replies |
mrs
Hi, I am about to add some pages of my own to the admin section created by PCMS, and I will need to add some editors.
My problem is that the editor from PCMS looks and acts differently to that of HTML editor's! I think PCMS uses CKEditor, and HTML Editor uses FCK editor.
I have purchased all versions of HTML editor and iRite, so does a previous version use CKEditor so I can match the style and the way it works.
Thanks.
Mat
you most likely have an older version of Power CMS That does not use the Newer CKEditor that is used in HTML Editor 3.
Power CMS version 2.1.1 is updated with the same version of CKEditor that is used in HTML Editor 3.
mrs
I'm not using the solution power CMS, I am using the extension PowerCMS Builder version 1.0.1. The HTML editor I have comes with CSS Form Builder version 2.0.0.
Having just read the download centre info, I think I need to update CSS Form Builder to 2.0.1, and install HTML Editor 3 afterwards. Is that what I need to do? Will that give me the correct looking editor? Do I also need to reinstall Validation Toolkit 2, Universal Email 4 or Digital File Pro 2?
Thanks.
Mat
mrs
I've just downloaded CSS Form Builder 2.0.1 - Support Release 2 (16.3 Mb), and installed it, but it lists in the Adobe Extension Manager as version 2.0.0 and not 2.0.1. Is this the correct version? Will it work with HTML Editor 3 properly?
yes, the Form Builder 2.0.1 version will allow you to install HTML Editor 3
mrs
But should it display as 2.0.0 or 2.0.1?
Both files I have downloaded both say 2.0.0!!
in the description, it should should show Build 27 for version 2.0.1
