Need Captcha to work
I created a form that is using data assist to insert record. Captcha requires <input type="hidden" name="MM_insert" value="form1" /> to make it work and no matter what I try, it still lets the person go through without using it. I recall this worked before!
I have used web assists form creator but I had so many issues with the validations not allowing users to submit because the the drop-down menus kept saying pick a value. It worked at first and then that started happening on all my forms, so I quit using it.
So can I make captcha work?
