SA 2.04 Javascript Errors
Thread began 1/26/2012 12:35 pm by Ian S | Last modified 1/30/2012 7:42 am by Jason Byrnes | 1491 views | 7 replies |
Ian S
Hi Guys,
Got a problem with SA 2.04 after installing the 2.1.0 Data Assist release (not sure if its related or not).
I uninstalled SA 2.04 and then DA 2.09. I only uninstalled 2.04 purely to ensure that its the last extension installed.
I then installed 2.1.0 and then SA 2.04 again.
Before starting dreamweaver I deleted the cache file.
When I now try to apply the Client Side validation message I get the attached screen shot.
Is there any easy fix for this or do we need to remote?
Cheers!
Ian
client validation was removed from security assist, it is now only included as part of Form Toolkit.
try uninstalling form toolkit then reinstalling it.
sorry, i misspoke, client validations are not in form toolkit, they are in Form Builder 2
what version of form builder 2 do you have installed? Make sure you have the 2.0.1 support release 3 versin installed that is available for download from the download center.
Ian S
Cheers Jason,
Do I need to uninstall SA 2.04 and Form Builder. Then Install Form Builder and then SA 2.04 again?
Thanks.
Ian
yes, you should uninstall both, then reinstall them with SA2 being last.
Ian S
Hi Jason,
Same problem after reinstalling with the latest versions / service releases I'm afraid.
No rush as I'm calling it a day now.
Cheers
Ian
Cologne
same here, unistall all, and then try and error to install in the right way :-)
