Client Detail Page
Im trying to make a detail page that has two tables joined and then filtered by the particular client. So they can download only there documents. Plz Help!
Thanx in advance. Eric
looks like you have set the orders.clientsID to hold the ID of the user from the clients.clientID column
try using the following recordset:
SELECT clients.client, orders.borrower, orders.county, orders.image, orders.loannumber, clients.username
FROM clients
INNER JOIN orders
ON clients.clientID = orders.clientID
WHERE clients.username = colname
then create a new variable in the variables section as:
type: text
default value: -1
runtime value: $_SESSION['MM_Username']
