CSS form builder, several problem (display and sumbit errors)
Thread begun 1/24/2012 5:52 pm by jonathan433046 | Last modified 1/25/2012 6:21 pm by jonathan433046 | 2357 views | 2 replies |
jonathan433046
I have installed css form builder on a site but mainly i got 2 problem, the first one is a display in dreamweaver that is out of box (in browser its fine see picture)
and the second one is when i am on the web and i try it i got several erros, but i do receive the email. So it is sending the form via email but the browser show many error
(se other pic or this link)
bijoux-personalise.php
Dreamweaver's design view is not a web browser. Sometimes, the design view in Dreamweaver just doesn't properly render the page.
A couple of possible causes are:
-A tag that is not closed properly.
-Dreamweaver's visual aids. you can disable them by going to View -> Visual Aids and checking Disable all.
there are a couple problems i see in the code for you page that may be causing this:
1) There is template code on the page, but the page is not derived from a template. for example:
<!-- TemplateBeginEditable name="panier" -->....<!-- TemplateEndEditable -->
2) The page does not have a proper doctype tag, this will cause display issues in some browsers.
add the following just before the opening <head> tag:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
see the following thread for details on the headers already sent error:
showthread.php?t=19285
jonathan433046
good
thanks with your suggestions everything work fine now, i think all the problem were from the template that i used to create my page initially in HTML
