error
Hi Jason
I get thos error on submitting a form.
Any ideas what it means?
Warning: set_time_limit() has been disabled for security reasons in /home/fhlinux130/r/raywilliamsmarine.co.uk/user/htdocs/contact.php on line 27
thanks
Ian
Hi Jason
thanks
Ian
I think that means that your hosting provider has restricted the user of the PHP set limit command.
You could try commenting that line out of your page ( add // before it) and see if that solves the problem.
Basically the time limit setting tells the page how long to wait before a timeout occurs, so it comes into use with slow connections, large file uploads etc.
Cheers
Ian
