Extension Manager hangs and fails to run
Thread begun 1/24/2012 8:58 am by superpac250441 | Last modified 1/24/2012 8:58 am by superpac250441 | 1390 views | 0 replies |
superpac250441
I am just bringing an issue which I have experienced over this past week to the attention of Web Assist customers.
If you are having a problem with your extension manager not loading and hanging at around 60 % of load, it might be as a result of installing Calendar2 from DMXZONE.
To fix the problem, please move this extension related files (dmxCalendar20.mxi, dmxCalendar20.mxi_air and dmxCalendar20.mxp ) out of C:\Users\<username>\AppData\Roaming\Adobe\Extension Manager CS5.5\Configuration\Extensions then retry. It should fix the problem.
I understand that DMXZONE are trying to fix the problem.
