Install
Thread began 1/24/2012 7:56 am by fxs430566 | Last modified 1/25/2012 3:29 pm by fxs430566 | 2373 views | 8 replies |
fxs430566
Install
I have already installed CSS Button Styler and CSS Menu Writer. Now when installing Data Assist I get an unending series of messages from Adobe Extension Manager;
A newer copy of the file C:\Users\fxs\AppData\Roaming\Adobe\DreamweaverCS4\en_US\Configuration\Shared\WebAssist\Library\UI_Media\btn_tx_centeralign.gif already exists. Do you want to replace it?
What am I supposed to do?
Is there an order for installing Super Suite so I avoid these messages?
OS Windows 7 64 bit Professional
DWCS4
newimage96814918
That's a real common error, which I don't really think is an error, just a warning that the help documents and other stuff installed with the last extention from webassist is being installed again with the extention just say yes to replace. I do all the time and have never had a glich. read above in the notices on install and javascript errors for more info.
And I know Jason put a list of best order to install extentions, I'm just not sure where. Just have a look around a bit and I'm sure you'll find it.
fxs430566
Got it, thanks.
newimage96814918, this is the post you are referring to in the General -> Dreamweaver forum:
showthread.php?t=24005
and thanks for jumping in and helping out, I appreciate it.
fxs430566, the newest extension is Security Assist 2, just make sure that is the last extension you install. and answering yes to all to the File Exists message is fine.
newimage96814918
Jason just so i'm clear, if we install datassit 2 agian because there was an update or release
should we uninstall security assist 2 and reinstall it last. I didnt last time when I went to datassist 2.09 and have'nt had any problems I can see, though I don't want none iether.
Thanks!
Tracy
yes, you should uninstall security assist and the product you are updating (DataAssist in this case), install the update, then reinstall Security Assist.
newimage96814918
Cool thanks Jason!
Tracy
no worries
fxs430566
Yep, that's what I did, thanks Jason.
