USPS shipping rules
Thread began 7/20/2009 2:35 pm by anonymous | Last modified 7/20/2009 4:23 pm by anonymous | 1597 views | 6 replies |
anonymous
USPS shipping rules
When adding shipping rules to eCart, is it like a case statement where they drop out with the first matching rule?
I have a special lower handling charge to apply when either of two items are added to the cart with nothing else, otherwise for all the rest I want to add the regular handling charge to the USPS rate quote.
I guess you would have to add a column to the cart "RegularRate" and set it to "1" for all items that have a regular rate and set it to "0" for your two special items.
Then create your shipping rules using "based on column subtotal" and use the special rate if the subtotal of "RegularRate" is zero (no regular rate items in the cart only special rate items).
anonymous
So reading between the line, every rule fires with each cart load?
anonymous
Do you see anything wrong with modifying the shipping rule by adding a case statement? Of course the obvious, I won't be able to edit in from the cart interface but other than that?
You don't need a case statement... just use two separate rules with different conditions so that one or the other will only fire.
anonymous
It's sort of hard to define that exclusive rule though. The first rule would be if it's only item A then use the lower handling rate. The second rule is if it's anything else or anything else including item A then use the higher rate. I'm not even sure how to make these exclusive without a case. Your extra column would work. I guess the advantage would be that the handling charge could be changed for items just by changing the database but I will also have to add that data field in and track it all the way through to checkout.
It's hard for me to keep my hands out of the code. I have to figure out how to manipulate the interface to get what I want and then I still find myself going to the code to check the result, at which point I think to myself why didn't I just code this the way I wanted it in the first place. LOL
The shipping "rules" are actually functions. "calculations" are just like any other column except that they aren't set by adding items to the cart they are defined by formulas... they are recalculated any time any column is updated which could effect it.
Any shipping or tax rule will callculate on demand when it is requested. So they aren't really fired with the cart load... they are fired any time you show them on the page or any time the GrandTotal is calculated.
