lipsum div
I dont know if this is what the html editor is doing but when I copy text into the editor I get a div tag called 'lipsum' which isnt what I want and need to remove it.
Thankyou for any help.
I'm not sure i follow.
Can you send a screen shot in a zip file to illustrate the issue.
The problem seems to have gone now since uploading the site live. But there does seem to be alot of <br> tags and it's pushing my text down. Is there anyway of turning styling off with the html editor?
the <br> tag will be added when you use the enter key. the enter key will cause a new line break.
this cannot be turned off.
