2.09 issue with Single Record insert
Thread began 1/20/2012 4:43 pm by Steve | Last modified 1/20/2012 4:48 pm by Jason Byrnes | 450 views | 1 replies |
Steve
Hello,
I saw the other issues this release has and ask if the problem I have is different or another issue the needs be addressed.
I added another table and need to insert another set of values... SO I used the insert single record from the link:
Server Extensions / WebAssist / DataAssist / Insert / Insert Single Record
This opens a new dialog forces me to create a session value unlike what I am used to where one is created or suggested for me. Then the page results in a fatal error which even Error reporting from PHP will not list.
The other or more usual way I would use the insert record extension is from this path:
Server Extensions / DataAssist / Insert / Insert Single Record
The dialog windows are different and also the first method inserts a new helper file:
<?php require_once("../webassist/database_management/wa_appbuilder_php.php"); ?>
The original method would insert this helper file:
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
Now both helper files exist, the page fails and I have to wonder if the updated methods also needed house cleaning to remove older versions of similar files??
