SecurityAssist 2.0.4 problems
Thread began 1/20/2012 4:39 am by fredalva299199 | Last modified 1/20/2012 12:06 pm by fredalva299199 | 1140 views | 4 replies |
fredalva299199
Hi, i am running dreamweaver cs5 and i've 2 errors displayed:
1/when i click on "create security page" there is a messag can't generate table in database.I don't understand because i can see my database in databinding panel and all is good.
2/when i try registration page in my browser, other error message display:
Fatal error: Call to undefined function WAValidateUnique() in C:\wamp\www\site2\registration.php on line 14
this is code in line 14:
$WAFV_Errors .= WAValidateUnique("site2",$site2,$database_site2,"ps4_users","UserID","none,none,NULL","".((isset($_SESSION["SecurityAssist_UserID"]))?$_SESSION["SecurityAssist_UserID"]:"0") ."","UserEmail","',none,''","".((isset($_POST["Registration_group_Email"]))?$_POST["Registration_group_Email"]:"") ."",true,2);
Could you help me to fix problems?
Fred
1) there are a number of possible reasons the table was not able to be created, usually this happens if the site definition does not have a testing server defined properly, or if the testing server is the remote server, not a local server.
The create table statement is saved to a .sql file so that you can create the database manually. Use the webassist/security_assist/site2_ps4_users.sql file that is saved to create the table. See the How to import a MySQL (.SQL) file to your database tutorial on the learning resources page for more details:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
2) see the following post for a fix to the error message:
showpost.php?p=106073&postcount=14
fredalva299199
Hi JASON,
1/database was setup manually
2/new file in post showed has resolved my problem but why it is not natively generated by securityAssist 2.04 ?must i change this file all time i need to use siteassist?
2) This usually happens if another extension like CSS Form Builder of Form Toolkit are installed after security assist. To prevent this from happening, Security Assist should be the last extension installed.
fredalva299199
yes i was first extension installed for me, i will reinstall extension.
thanks
