Support fix in DataAssist
DA 2.0.9 has been released, but the release notes do not indicate that the error in 2.0.8 which led to the support fix has been corrected.
Is it correct that the support fix does not need to be applied to the new release.
the library file in version 2.0.9 includes the fix from the known issue, it is still in the download center for users who have not updated to 2.0.9
this is why the description for the support fix specifically states version 2.0.8
Thanks for the quick reply. I don't remember which extension, but there has been one or two in the past where the support fix was still required.
This information should be explicit in the release notes. The release notes only list one item fixed and it is not the same issue (or at least is not obviously the same issue) as the one that the support fix corrected.
That means that the release notes are also not a complete version history and begs the question as to what else has changed that is not listed.
