Upgrade from iRite to HTHML Editor 3.0.2
What is the procedure for updating a website from iRite to HTML Editor?
Does HTML Editor take care of this upgrade or do I need to recode the page?
Thanks!
Thanks!
you will need to first make note of the name of the iRite instance, then remove it from the page.
then insert a new HTML Editor instance, make sure to give it the same name as the Irite instance.
Ok, so it is a manual process, not an automatic upgrade. But it sounds simple enough. Thank you
