subdomain file path issue
Thread began 1/16/2012 9:36 pm by welcomcat385026 | Last modified 1/26/2012 6:36 pm by welcomcat385026 | 5011 views | 10 replies |
welcomcat385026
Form is not sending an e-mail, because of the subdomain file path issue.
Form is on index.php within the subdomain folder.
MaindomainFolder/SubdomainFolder/index.php
WebassistFolder is :
MaindomainFolder/Webassist/email/mail_php.php, etc etc
I used absolute path, however it didn't work.
Best regards,
can you give a few more details please?
Are you getting an error message? If so, whats the error?
If you are not getting an error message, the file path should not effect whether the email is being sent or not. How are you arriving at the conclusion that the file path is the cause?
Can you provide a link where i can see the form to test please.
In Universal Email, did you set a go to page to redirect to after the email has been sent?
after submitting the form, does it redirect to that page?
If so, it is trying to send the email, but the SMTP server is not relaying it.
In Universal Email, for the SMTP server settings, what did you set for SMTP server and port?
Who is you host? your host will be able to tell you what SMTP server address to use and what port to use.
welcomcat385026
Thank you for working on this wacky issue.
I gave up on trying to point subdomain to main domain directory. I tried an indipendent FTP directory for this subdomain, so it has independent remote file definition. Mail function still did not work. So I fowarded the subdomain to the file in the subfolder of the main domain site. UE is working perfectly now. Redirection to "Thank you" page is working too. The problem seems to have occured when I changed the file name from name.php to index.php.
My hosting server is 1and1 and setting for UE is : UTF-8, smtp.1and1.com (This setting has been working properly until I introduced FORM in index.php Subdomain.
I also tried absolute path and changed paths wherever necessary, but imail function didn't work.
Do you think you can experiment with FORM with UE on subdomain index.php in main domain site?
PS: Redirection to "Thank you" page did not happen at all.
Best regards,
ok, well if the redirect to the thank you page is not working, that means the email behavior is not being triggered.
send a copy of your page so i can take a look at the code please.
welcomcat385026
Independent directory
Thank you for looking into this subdomain issue. Files I'm sending are set in the independent directory(FTP a/c) for the subdomain Mail function did not work. Previously I was using the directory of the main domain. Neither of the setting did not work. When I fowarded the subdomain to the particular subfolder with named file instead of index.php inside the subholder of the main domain, it worked.
Best regards,
indexfile.txt
waue_index_1.txt
the issue caused by using the currant page submit trigger.
In universal email, set the trigger to use the Submit button pressed instead of current page submit.
welcomcat385026
Thank you it worked.
One more question: How do I choose trigger for each situation. I couldn't find in pdf tutorial.
Best regards,
I dont understand what you are asking. what do you mean by "Each Situation"?
welcomcat385026
Sorry I didn't explain enough.
To choose a trigger : any form submitted, before page load, current form submitted, button pressed. How do I guess which is most appropriate.
Best regards,
the first factor you need to consider is how many forms are on the page. if you have a page with 2 forms, that are both set to post back to the same page, you will probably have separate server behaviors for each form. In this case, using the current page submit or any form post trigger would cause both behaviors to trigger when one of the forms is submitted.
to prevent that, use the button pressed trigger. there will be one for each submit button, make sure they are named uniquely.
many times if you have 1 form on the page, the current page submit trigger is the best to use. In your case it was not working because the form is on the default index page. current page submit looks at the page name in the address bar of the browser, the domain in the browser and compares that against server variables to make sure the match.
when index.php was not included in the address, the currant page submit trigger didnt work, because the comparison was "is '/' equal to '/index.php'"
you can read more about trigger in the "WebAssist Triggers: Unleash the Power" tutorial on the learning resources page:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
