DataAssist Wizard crashing Dreamwaver CS5
Thread began 1/12/2012 8:16 am by bob402889 | Last modified 1/16/2012 10:23 am by Ray Borduin | 1110 views | 3 replies |
bob402889
Whenever I try to use DataAssist Wizard 2.0.8 Dreamweaver CS5 crashes. Other WebAssist plugins are working fine. Sometime this happens on the first screen and other times its the last screen,
Bob Hahn
First, Delete the Dreamweaver Cache file from the users configuration folder:
it could be a memory issue. Try closing the Files panel in Dreamweaver and the Server Behaviors panel before starting the wizard.
bob402889
Re: DataAssist Wizard crashing Dreamwaver CS5
Thanks for the info. I did what you said and I am still have the problem. This time the wizard went faster and crashed on the last screen.
Bob Hahn
I will open a support incident so that we can look into this with you directly.
