encoding à è ì ò ù
Thread began 1/12/2012 6:28 am by Massimo | Last modified 1/16/2012 12:18 pm by Ray Borduin | 1712 views | 3 replies |
Massimo
encoding à è ì ò ù
I try insert in my db the italian caracters à è ì ò ù as html:
à
è
in html edit I try to encode latin, greek, both and none but not work.
In my page I read correct char à è ì ò ù, but in my db (I have also latin1 default collation) are insert à è ì ò ù.
Any idea for this
edit the database connection file to force it to use the UTF-8 character set.
In the database connection file add the following code on a new line just befoer the closing php tag "?>"
so change:
mysql_set_charset('utf8',$ConnectionName);
where ConnectionName is the name of the connection.
Massimo
with this solution and charset=utf-8 in page all work, but so can't pass validadion. There aren't any way to insert directly in dB html entities with html editor (if I write à in editor he store à in db) ?
You can update the code where it is inserted and use the htmlentities() function to encode the string where it is inserted into the database.
