Center Horiz Menu with evenly spaced Menu <li> items
Thread began 1/11/2012 10:23 am by toni272059 | Last modified 1/12/2012 4:45 pm by toni272059 | 3809 views | 2 replies |
toni272059
Center Entire Menu on Page
-- I am trying to center the entire horizontal menu on the page while also having even spacing between the Main menu items.
-- I have tried margin: 0 auto; did not do anything
Equal Spacing between Main menu items
-- in order to achieve the equal spacing between menu items I removed the box item width and increased padding on both left and right.
Problem: Level 1 Sub Menu items are not centering under parent Main menu item
-- text align is set to center for all menu items, both Main and Level 1 however the sub menu group is not centering under its parent item
Test page for horizontal menu link: crew-2.html
UPDATE
I have been working at customizing the CSS to achieve a visual centered look and to adjust the Level 1 Sub Menu to line up under its Level 0 parent
Upon reviewing the page with browsers on both PC and MAC the menu styling is not working with IE on PC. It does work with Firefox, Opera, Chrome and Safari on PC and Firefox and Safari on MAC. Not working on IE 7 and IE 8 is a BIG PROBLEM! What's not working/What am I doing wrong or missing?
your top level menu does not have a width specified.
for compatibility with IE, you must specify a width and height for the menu items using a pixel measurement.
leaving the width or height blank, or using auto will not work in IE.
wher you are trying to give a unique width to each top level item, you will need to add an inline width to the menu html
for example:
<li><span><a href="index.html" style="width: 80px;">HOME</a></span></li>
toni272059
I added a width to the overall <ul> and that solved the IE problem. Setting fixed widths for the individual <il> does not work cross browser if the goal is to create equal spacing between each menu item.
After searching online I found one possible solution -- instead of float:left; for <li> use display:inline-block; which I am testing out.
