Where is PowerCMS?
Has PowerCMS been replaced or discontinued? I noticed there is now a PowerCMS Builder, is this what is used in place of PowerCMS. I wasn't able to find PowerCMS on the website.
Thanks,
Thanks,
the Power CMS Solution pack has been replaced by the Power CMS Builder Dreamweaver extension.
Thanks Jason, How the does the extension compare to the solution package as far as ease of use and it's functionality?
The only difference with the extension is the addition of the Dreamweaver access points under the WebAssist -> CMS menu
I just watched the video, What kind of prep on the server has to be done with regard to the database. Am I just creating an empty database to connect too and it is populated as I go?
There really isn't much of those details in the video.
yes, you need to create the database, the extension will create the CMS tables when it is used.
