Site Sculptor Crash
Thread begun 1/09/2012 7:09 am by Endrio | Last modified 5/30/2013 4:36 am by lisa411800 | 5713 views | 15 replies |
Endrio
Site Sculptor Crash
I am having problem with Site Sculptor 1.0, Dreamweaver CS5 crash after wizard.
Endrio
Delete the Dreamweaver Cache file from the users configuration folder:
Endrio
I do not have this path on my mac, I use Dreamweaver CS5:
/users/[username]/Library/Application Support/Adobe/Dreamweaver CS4/en_US/Configuration/
Regards
Endrio
for CS 5, the path should be:
/users/[username]/Library/Application Support/Adobe/Dreamweaver CS5/en_US/Configuration/
Endrio
I did as described in the procedure, but Dreamweaver still crashes after the wizard
danielsebas
I have the same issue
I have CS5 and it crashes when I use any extension. I upgraded to Data Bridge and Design Extender and uninstall all my extensions but surveyor and theme it before installing DB and DE. When I try to use any extension Dreamweaver crashes, I already deleted the .dat file and still have the error. When I use Site Sculpture, I finish configuring my site, I press the Finish button and Dreamweaver crashes and the same happens with MenuWriter and all other extensions. I only have WebAssist extensions installed.
Rood's Media
Dreamweaver CS5 Crashes after Site Sculptor Wizzard
Hi Guys
Any further word on this issue? I am having the exact same issue with my setup. Even if I use the default settings and templates. After the Site Sculptor wizard runs, Dreamweaver quits.
Dreamwevaer CS5 Build: 4909
Site Sculptor 1.0.0
Mac OSX 10.8.2
Rood's Media
Clearing Dreamweaver Cache Doesn't Work
Hi Guys
I dumped the Dreamweaver Cache and I still have the same issue. I am looking at buying Design Extender but I wanted to see what I could do with my old Site Sculptor extension first since I never gave it a fair go when I first bought it.
I always seem to have some sort of bug with all the WA products I buy. The only one that has worked reliably so far is the CSS menu builder.
Please help. Thanks.
