footer disappeared
The template footer to the form page disappeared. It is the only page with the problem. Any advice on the best way to fix this... I can't see any obvious reason. The page is attached.
Thank you!
johna1964
Thank you!
johna1964
could be a php error is occurring. try adding the following code at line 1 to turn on error reporting:
error_reporting(E_ALL);
also, please post a link to your site where i can see the problem .
Hi WA... My footer has disappeared on me... I've looked over the code and everything. The structure is correct. Here is the link to the website. There is only this page (index.php) and and a template (testing it for Site Sculptor).
www.siteassist.depidesign.com
it looks like the footer content is:
©2012 Stars & Stripes Athletics :: www.stars&stripesathletics.com :: All Rights Reserved!
i can see this when viewing your page in Fire Fox, Chrome, Safari, Opera, and IE.
I am not able to reproduce the problem.
