disappearing text in list values
Thread began 1/07/2012 7:27 am by cgdm93096 | Last modified 4/02/2015 4:07 pm by Ray Borduin | 1402 views | 5 replies |
cgdm93096
When I'm creating list values after adding about 4 items the the text disappears, it's still there it just becomes invisible. After blindly adding a couple more items the text re-appears, then after a few more items it disappears again.
My operating system is Windows 7 using Dreamweaver CS5.
What version of form Builder are you using?
make sure you are using the CSS FOrm Builder 2.0.1 Support release 2 version available in the download center, if you are using a previous version, make sure to uninstall it from the extension manager before installing the newer one.
cgdm93096
Thanks, I didn't realize an update was avaliable. After I installed the update everything cleared up.
Thanks again!!
Mike Perry
I'm having this same problem with DataBridge (1.2.2), CS6, Windows 7 Pro 64 bit. OS is current.
Thanks,
Mike
I was able to reproduce this issue. We'll get a new build out today to fix it.
Mike Perry
Thanks, Rsy. . .
