1st menu item not working
Thread begun 1/06/2012 5:37 pm by simmo515303621 | Last modified 1/18/2012 3:07 pm by simmo515303621 | 2331 views | 4 replies |
simmo515303621
Hi Crew,
I have a very strange issue.... Its seems my first menu item link does not work... It simply refreshes the page..
Now I do have some PHP code - that I will post here, but I have also removed all code and the issue still persists.
main.php?pages_id=5 is the website im working on
if you click home - nothing happens, but you can see that the link is working fine.. ALl code is fine.
The Nav is in a div that is absolutely positioned - I dont have a z-index issue, but I have also tried with nothing on the page and no css positioning.. still no go...
Here is the PHP i am using wrapped around the first href in the parent li.
<a href="<?php if($row_menuwriter_pages['pages_id'] == '1') { echo $row_rsSitewide['site_url']."/"; } else { echo($assumedRoot)."main.php?pages_id=".$row_menuwriter_pages["pages_id"];} ?>"><?php echo $row_menuwriter_pages["pages_name"]; ?></a>
change this code:
<a href="<?php if($row_menuwriter_pages['pages_id'] == '1') { echo $row_rsSitewide['site_url']."/"; } else { echo($assumedRoot)."main.php?pages_id=".$row_menuw riter_pages["pages_id"];} ?>"><?php echo $row_menuwriter_pages["pages_name"]; ?></a>
<a href="<?php if($row_menuwriter_pages['pages_id'] == '1') { echo $row_rsSitewide['site_url']."/index.php"; } else { echo($assumedRoot)."main.php?pages_id=".$row_menuw riter_pages["pages_id"];} ?>"><?php echo $row_menuwriter_pages["pages_name"]; ?></a>
simmo515303621
Hi Jason,
Thanks for the reply - This doen not work either, I can even put a completely different link and it wont work either?
Even if I leave the code as standard CSSMW code it still wont work on the first link
The problem is caused by this code you have added to the head tag:
var $riol = jQuery.noConflict();
$riol(document).ready(function() {
$riol('.shuffle').randomImage({path: 'theme/banners/'});
$riol('a:first').click(function() {
location.reload();
return false;
That code updates the first link on the page and makes it refresh the page instead of going to the page it references. I think you can just remove the second section of that code to correct the problem.
location.reload();
return false;
simmo515303621
Hi Ray,
Ahhh ok I see thanks for that! I would have never figured that one out!
