Can site sculptor be used with Powerstore
Can site sculptor be used with Powerstore to give a custom design/theme to powerstore pages? If not, is there a procedure that can be done to get powerstore pages into an existing design?
to create a custom theme, you would need to make a duplicate of one of the existing theme folders.
go to webassist/themes and select a theme as a starting point, copy it and save it as webassist/theme/<your theme name>
you then need to edit the webassist/theme/<your theme name>/templates/index.dwt.php and page.dwt.php files to your design.
