Change in Shipping Charge
Thread began 1/02/2012 3:49 pm by James L | Last modified 1/11/2012 12:52 pm by James L | 1054 views | 8 replies |
James L
My client's site has been functioning fine for almost a year using U.S. Postal Service lookup for calculating shipping, however he now wants to change it so that 1 or 2 items still use the USPS calculation, but if they buy 3 items the shipping is free (i.e. 0). I can't seem to figure out how to do this.
I tried the following code, but it doesn't work:
//eCart Rule
function WAEC_new_ProRes_USPSShipping() {
$totalShipping = 0;
if (true && (("USPS"=="USPS")&&(isset($_SESSION["new_ProRes_USPS_Quote"]))&&(floatval($_SESSION["new_ProRes_USPS_Quote"]) != 0) || (sizeof($this->Items) == 3))) {
$totalShipping += 0;//Result
return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
Please help me fix this code.
Thanks.
dont edit the code, use the eCart object editor to modify the shipping rule.
open the confirm page or any other page that has eCart applied to it, then open the server behaviors panel (Window -> Server behaviors).
in the list of server behaviors, double click the eCart object server behavior.
in the eCart object editor, go to the shipping tab and edit the USPS Shipping rule.
add a new trigger to the rule:
"Subtotal For Any Column"
If the subtotal of column "Quantity" is "<=" a value of "2"
James L
Change in shipping charge
Thanks for the answer but it seems truncated. This starts with "IF" therefore shouldn't there be something that goes after: "If the subtotal of column "Quantity" is "<=" a value of "2" "?
In the eCart Shipping rules, the trigger section is the if statement.
the calculation section defines the rule that will be applied if the trigger condition is met.
you already have the calculation in place, your question was basically how to change the conditions that need to be met for the calculation to be applied. you do this by adding the additional trigger.
James L
I can't seem to make this work
Help! I tried to apply this to the site but something is so screwed up now I had to shut down the cart function (client not happy).
I've attached a screen cap of the e-cart shipping rule I used, and also a screen cap of the error message.
What I'm trying to do is for a quantity of 1 or 2, shipping charge comes from the USPS lookup, but for a quantity of 3 there is to be no shipping charge.
instead of adding the new trigger, you replaced the old trigger with the new one.
you need to have 2 triggers:
Based on USPS Shipping quote value > 0
AND
Subtotal of Column quantity <= 2
James L
still have errors
i'm still getting the errors for quantities 1 & 2, but not for 3.
I've attached 2 screen caps one for each setting. Please tell me what I'm doing wrong.
you are not using the correct triggers.
your triggers are:
Subtotal of Column quantity > 0
AND
you need to use the triggers:
AND
the first trigger needs to be:
not:
James L
Yeaaaa! It works!
Finally! Thank you so much for your help.
