cart display and user problem
Thread began 1/01/2012 12:59 pm by bigup40389823 | Last modified 1/03/2012 10:49 am by Jason Byrnes | 526 views | 2 replies |
bigup40389823
I have my basket showing on my page which is working fine but if user1 logs in and adds something to the basket and then logs out and then user2 logs in, the basket is still showing what user1 added, it's like it's not destroying the cookie or something.
This should be fairly simple, any ideas?
Thankyou.
Ian S
I might be wrong, but I am not aware that any shopping cart is user related, unless you are providing the ability to save and restore a cart against a user profile.
The cart contents are normally stored for the length of the session / cookie (depending on what method you are using), but I'm not aware the carts are ever user specific.
If you want to achieve this you would need to personalise the 'logout' script to save current cart contents and then empty basket. Then on log in your script would need to check for a saved cart and then repopulate.
Cheers
Ian
Like Ian says, the cart contents are not user specific.
if you want to force the cart to clear when a user logs out, you will need to add a clear cart behavior to the logout page.
