Contact Form - doesn't send or display thank you
Thread begun 12/26/2011 11:10 am by markf425338 | Last modified 8/21/2014 1:46 pm by Jason Byrnes | 6725 views | 10 replies |
markf425338
I have successfully placed the Contact Form on 3 other sites including my own. For some reason I cannot get it to work correctly on a new site. I have it configured the same as on the other sites but on this new installation it won't display the Thank You confirmation page and it doesn't e-mail the info.
I'm not sure if this is pertinent, but the new site is here:
contactus.php
You may notice the address. this is a development address and will ultimately change to contactus.php. I'm not sure if that has any bearing on this problem I'm having.
Thanks in advance for any help you can provide with this.
you deleted the security question form element, but not the code to validate it.
delete the following line:
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
markf425338
Of course that was the user created problem. Thanks Jason!
markf425338
Same Problem - Again
I am having trouble with the contact form again. It displays and can be filled out correctly. Once submitted it does not display the Thank You confirmation page and it doesn't e-mail the info.
Tried to start a new thread for this but couldn't seem to find where / how to do that.
Any help very much appreciated
try changing line 28:
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)))     {
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
markf425338
Thank you Jason. I changed that line of code per your instructions but it still doesn't work. I can fill out the form and submit it but no Thank You message appears and I do not receive the form.
markf425338
see th eprivate message
i enabled error reporting by adding the following code at line 1:
<?php error_reporting(E_ALL); ini_set('display_errors','on'); ?>
This shows the following error
Warning: session_start(): open(/var/php_sessions/sess_d97e9feb4f90e0f6ec6b740fcda15f06, O_RDWR) failed: No such file or directory (2)
this is caused by a setting in the php.ini file, you will need to contact the host to have them correct the session.save_path
markf425338
that's odd because I have exactly the same ContactForm103 at another site on the same host and it works fine.
Link to other site is in private message section
I contacted the hosting company and they made a change to the session.save_path fiile and now the form is working.
Thanks for your help!
