Insert Uploader failing
This is an extension I have used extensively. I just can't get it to work today. Nothing happens. I've rebooted, dumped .dat file, etc.
I tested again on another domain and I still same result.
No code is generated.
<!DOCTYPE HTML>
<html>
<head>
<meta charset="UTF-8">
</head>
<body>
<form action="" method="post" enctype="multipart/form-data" name="form1">
<label for="test"></label>
<input type="file" name="test" id="test">
<input type="submit" name="submit" id="submit" value="Submit">
</form>
</body>
</html>
Since holiday, I don't expect a response. I'll download extension and try again.
All good. I re-installed digital file pro and it is now working... Sorry for the noise.
OK... just a report on weirdness... once I reinstalled, then, all previous efforts filled the page... very spooky.
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../logos/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "280",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../calloutimages/",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End?>
// WA_UploadResult3 Params Start
$WA_UploadResult3_Params = array();
// WA_UploadResult3_1 Start
$WA_UploadResult3_Params["WA_UploadResult3_1"] = array(
'ResizeWidth' => "200",
// WA_UploadResult3_1 End
// WA_UploadResult3 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "fileField", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "fileField", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult2_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult3");
WA_DFP_UploadFiles("WA_UploadResult3", "fileField", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult3_Params);
Sharing only in the interest of trouble shooting...
I'm glad I left this solution posted. It happened again. Gremlins.
