Horizontal/Vertical dynamic menu
I need to have a repeating menu going horizontally with vertical dropdowns, both being dynamically fed. I have successfully created the vertical dropdowns, but at this point, I must create a different recordset for each column. I need to have one recordset for each column, just having it repeat, pulling in the appropriate vertical dropdown for that column.
Make sense?
