non functional code
Thread began 12/22/2011 2:29 pm by i.edwards384429 | Last modified 12/22/2011 11:57 pm by i.edwards384429 | 3769 views | 4 replies |
i.edwards384429
non functional code
Hi Jason
really hope all is well with you and you have your Santa suit ready for the big day!!!
My second foray into frame work.
Trying to create a type of flow chart using page switching.
So the initial page drawn from the plugins directory works ok when previewwd.
When I add a seconf page nothing is shown
I've followed the video demo but cant see why it fails.
The page code is beow as it's not live yet can you see why is fails?
thanks
Ian
require_once( "webassist/framework/library.php" );
require_once( "webassist/framework/framework.php" );
if(true){
// WebAssist Framework Builder Dynamic Plug-in: $WA_interactive_intro_1324592544583
switch(isset($_GET["form"])?$_GET["form"]:""){
case "[new value]":
$WA_interactive_intro_1324592544583 = new WA_Include("_plugins/interactive_intro.php");
break;
case "hoone":
$WA_interactive_intro_1324592544583 = new WA_Include("_plugins/handoperated_one.php");
break;
default:
break;
if(isset($WA_interactive_intro_1324592544583)){
require($WA_interactive_intro_1324592544583->BaseName);
$WA_interactive_intro_1324592544583->Initialize(true);
// End: WebAssist Framework Builder Dynamic Plug-in: $WA_interactive_intro_1324592544583
<head>
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/mootools/1.2/mootools-yui-compressed.js"></script>
<title>Impulse and Heat Sealing Equipment Suppliers | Pouch Sealers | Bag Sealers | Spare Parts Stockist | All Sealers</title>
<meta name="distribution" content="Global" />
<meta name="reply-to" content="enquiries@pcjsealers.co.uk" />
<meta name="revisit-after" content="15" />
<meta name="robots" content="index,follow" />
<meta name="description" content="Buy online Impulse and Heat Sealing Equipment at the best UK price" />
<meta name="keywords" content="Sealers 100mm - 350mm Sealers 400mm - 550mm Sealers 600mm + Spares Hulme Martin Sealers Audion Sealers Special Delivery Vacuum Packers Pouches Hand Sealers Foot Sealers packsealer, Impulse Sealers, Heat sealers, vacuum sealer, sealers heat, sealers, poly bag sealers, plastic bag sealers, hand sealers, polybag sealers, impulse heat sealers, beep sealer, polypropylene bag sealer, impulse sealers, hand operated, foot operated, double impulse, right angle, direct heat, automatic, portable heat sealers, direct heat sealers, bag sealer" />
<meta name="language" content="English" />
<meta name="author" content="Ian Edwards" />
<meta name="rating" content="General" />
<meta name="copyright" content="Edwards Micros" />
<!--[if lte IE 6]>
<style type="text/css" media="all">
@import url("webassist/plugins/main_menu/menu_ie.css");
</style>
<![endif]-->
<link rel="stylesheet" type="text/css" href="_css/dark_styles.css" />
<link rel="stylesheet" type="text/css" href="webassist/themes/pcj/css/configurable.css" />
<!--[if IE 6]>
<link rel="stylesheet" type="text/css" href="webassist/themes/pcj/css/ie6.css">
<![endif]-->
<link href="p7mbm/p7MBM09h.css" rel="stylesheet" type="text/css" media="all" />
<script type="text/javascript" src="p7mbm/p7MBscripts.js"></script>
<?php echo((isset($WA_interactive_intro_1324592163078))?$WA_interactive_intro_1324592163078->Head:"") ?><?php echo((isset($WA_interactive_intro_1324592400278))?$WA_interactive_intro_1324592400278->Head:"") ?><?php echo((isset($WA_interactive_intro_1324592544583))?$WA_interactive_intro_1324592544583->Head:"") ?>
</head>
<body>
<div class="ps_head">
<div id="header" class="wrapper">
<div class="logo">
<a href="index.php"><img id="headerLogo" alt="Heat and Impulse Sealers" src="images/logo250_120.png" /></a>
</div>
<div id="menu">
<div id="p7MBM_1" class="p7MBM09h">
<ul>
<li><a href="index.php">Home</a></li>
<li><a href="http://pcjsealers.co.uk/store">Store</a></li>
<li><a href="support.php">Manuals & Videos</a></li>
<li><a href="http://www.pcjsealers.co.uk/contactus.php">Contact Us</a></li>
</ul>
<!--[if lte IE 6]>
<style>.p7MBM09h a {height:1%;float:left;} .p7MBM09h, .p7MBM09h li {height:1%;}</style>
<![endif]-->
P7_MBop('p7MBM_1',1,0,0,0,-10,12,240,240,1,1);
</script>
<div class="p7mb_clearfloat">&nbsp;</div>
</div>
</div>
</div>
</div>
<div class="banner">
<div id="banner" class="wrapper">
<div id="featuredWrapper">
</div>
<div class="bannerInfo">
<h1><h1>
<span class="ps_highlight">For Heat and Impulse Sealers etc</span>!</h1>
</h1>
<p>
Unlike other Heat and Impulse sealer suppliers PCJ Sealers believe that their responsibility is to ensure you purchase the correct machine for your project.</p>
<p>It is PCJ Sealers aim to provide the ultimate in support to their clients!!!</p>
<p>Our 40 years experience means we have a wealth of experience which we are ready to pass on to our clients.</p>
<p>Using this page and associated links we will try to help you choose the correct machine. </p>
<p>If you are still not sure which machine to purchase then help is always available via the support line where you can be assured of a fast response to any queries raised. Telephone 0844 5760696</p>
<p>It does not matter if your query is simple of complex - we are here to help.</p>
<p style="text-align: center;">&nbsp;</p>
</div>
</div>
</div>
<div>
</div>
<div class="main">
<div id="main" class="wrapper">
<div class="content">
<div class="block"><?php echo((isset($WA_interactive_intro_1324592544583))?$WA_interactive_intro_1324592544583->Body:"") ?> </div>
</div>
</div>
</div>
<div>
<div id="footer" class="wrapper ps_footer">
<?php include("_includes/copyright.php"); ?>
</div>
</div>
</body>
</html>
i assume it is the interactive_intro.php page that does not show?
the trigger to show that page is for the URL variable form to have a value of "[new value]"
pagename.php?form=[new value]
that doesnt look correct to me.
edit the dynamic plugin behavior and change the trigger value for the second page.
i.edwards384429
update
Yep 11pm here hence the typos
thanks
Ian
PS knowing your love of the ultimate question did you see that there will be a stage show using the original BBS cast????
No, I didn't hear about that, I'll have to keep my eye out for details.
On a related note, I just say the Hobbit trailer today, already looking forward to next December
i.edwards384429
updates
entertainment-arts-16299949
Have a good holiday
Ian
