server validations
Thread began 12/21/2011 4:37 pm by johna1964 | Last modified 12/22/2011 9:51 am by Jason Byrnes | 486 views | 1 replies |
johna1964
server validations
The javascript issues are now solved; however, i am unable to add more than one server variable for server validation.
Each time I try to add server validation, other than the first one (cc type) I recieve the following dw message:
"Making this change would require changing code that is locked by a template or translator. The change will be discarded."
Any solutions?
Thank you.
johna1964
Are you adding all of the server variables in the same instance of the Server Validation or adding a second server validation instance?
you should only use one Server Validation server behavior and add all of the validations to that one instance.
