SA2 with Universal Email help
Thread began 12/20/2011 6:44 am by saf01 | Last modified 12/21/2011 10:01 am by saf01 | 887 views | 3 replies |
saf01
Im using Windows XP with DWCS5.5, all extensions loaded.
I ran SA2 to generate security pages wizard (with and without password encryption), its created everything fine and tested.
These are my problems:
Problem 1:
Ive registered myself as a test using my email on the SA2 register form.
Ive checked the database and its adding the fields to the db. Its not adding IP address though. I can login to view my userupdate page. Now when I go to the forgotpassword page and enter exactly the same email I see in my db and fill the security questions, I keep getting:
Your email address could not be found in our records. Please try again message.
Ive ran the wizard about 7 times and the same thing (also emptied the database and registered again and created new db). Ive checked the Email Server behaviour and the Look up column is correct as suggested in another post. Ive added my SMTP details from the SA2 wizard for forgotpassword wizard edit.
Problem 2:
I want to add a simple functionality that when someone registers, I get an email saying someone has registered with the details they filled out on the form.
I tried many times to add Universal Email to the register form, and having great difficulty because as soon as I add universal email, the register page form fields cant be seen on my test server - bascially all the Spry and other functions keep geeting stripped on the register form.
Lastly Can SA2 be used with PowerCMS builder together?
Please can someone help.
saf01
ok. Problem number 1 solved - on my host I had to add a session path in a php.ini and upload it to the domain so it can write sessions into - now all is working, brilliant!!!
Can someone please help me with problem 2. Thanks
saf01
Hi Jason,
Ive replied to the ticket.
Thx.
