Sending site to live remote server
Thread begun 12/19/2011 2:56 am by JamieEff | Last modified 12/23/2011 1:56 am by JamieEff | 2014 views | 4 replies |
JamieEff
Hi
I am having a few problems from moving a site from testing and local to the remote server.
Firstly, I had to change the connection details manually to what i set the database up as... will I have to do that everytime or is there a way to 'mirror' the database connections?
Secondly, am getting this error which I have no clue how to fix:
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/sewarrbt/public_html/WA_Globals/WA_Globals.php on line 42
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/sewarrbt/public_html/WA_Globals/WA_Globals.php on line 67
Thanks in advance
Jamie
You will need to change the connection details manually each time.
for the error message, did you export the data from the local MySQL Database and import it to the remote database?
Using a mysql gui tool like PHPMyAdmin, you will need to export the local PowerCMS Database and import it to the remote database.
JamieEff
Thanks for the reply Jason
Re the export / import side of things.... how do I go about that?
Cheers
Jamie
in the PHPMyAdmin for your local server, selct your power cms database, then go to the Export tab. you can leave all of the defaults as is, and check the save as file option.
once the sql file is exported, see the "How to import a MySQL (.SQL) file to your database" tutorial on the learning resources page for details on importing the database.
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
JamieEff
thanks Jason
Something for me to get my teeth stuck into over Christmas
Hope you and the team have a great holidays and some well deserved time off.
Cheers
Jamie
