Put 2 Captcha in the 1 website?
Thread began 12/18/2011 10:07 am by shanekk22422510 | Last modified 12/21/2011 8:13 am by Jason Byrnes | 2177 views | 5 replies |
shanekk22422510
Can someone help i am trying to put Captcha on a contact form it works fine
But i am also needing to put Captcha on a booking form but when its live it will not work the booking form stil sends when i put the wron code in
on the booking pages the Captcha is still Captcha_Security_Code_1 when i go to Variable to Validate so i think this is why
Ian S
Yes, it is possible to have more than one Captcha on a site.
When the page with the Captcha loads it populates the Captcha_Security_Code_1 session variable with that pages instance of the captcha value.
How have you got the validation set? Is it set to case sensitive or not?
Cheers
Ian
shanekk22422510
I have done everything the same as the way it is done in the webassist video for formtool kit
But i done it the same for the 2pages am i ment to do something different on the booking page so it will not pick up the contact page?
I have set it to not case sensitive.
Im not sure what im ment to do it works in 1 page but not the other
please end a copy of the page it is not working for in a zip archive.
shanekk22422510
Hi
Its the booking.php were it is not working will still let the form go with out putting in the code
i have also sent the contact.php witch is working
When i remove the contact form captcha the booking form works fine
New folder (4).zip
On the booking.php file, in the Like Entry validation, you have set the Server Variable and Same as option to both use the same Security_Code_1 form element.
when configuring the Like Entry validation, Set the Server variable to use the Security_Code_1 form element and set the same as to use the captcha_Security_Code_1 Session variable.
