Quick question
I have installed all extensions included in supersuite.
I dont see dynamic dropdowns in the server behaviour list
How do I access dynamic dropdown functions?
A lot of the functionality of Dynamic Dropdowns is actually Client Side, so you will find most of it in the Tag Inspector window, rather than Server Behaviours.
Firstly you need to create a dynamic array using the Server Behaviours > WA Dynamic Dropdowns
Then you need to create the client side triggers that are available in the Tag Inspector window.
Hope this helps
Cheers
Ian
Thanks Ian but the problem is, I can't see any reference to Dynamic Dropdowns in the server behavior list.
Ah, OK
Have you tried uninstalling and reinstalling the extension?
It doesn't appear under the Web Assist menu, it just appears as WA Dynamic Dropdowns.
Cheers
Ian
Thanks,
I didn't realise it was a seperate extension.
In that case it doesnt look like I even have the extension and it isn't available in my "download centre" at webassist.
Is it a part of Supersuite?
dynamic dropdowns was discontinued about 3 months ago, it is no longer offered for sale and is not a part of new supper suite purchases.
Pity, It seems to be a popular extension. Any particular reason for it's demise?
I just bought Data Bridge. Does this mean that I don't have the extension? I don't see it anywhere but it is on the list as a feature. Please Advise... I am very confused.
Dynamic Drop Downs is a part of the Data Bridge extension.
the Access points for Dynamic Dropdowns is in the Server behaviors panel, and the Behaivors panel, click plus and select WebAssist -> Dynamic Dropdowns
