Existing PowerCMS issue
Thread begun 12/15/2011 1:40 am by info396563 | Last modified 12/15/2011 11:55 am by Jason Byrnes | 1063 views | 1 replies |
info396563
Hi
I currently have an issue with Power CMS (Support ticket ref: 134716) whereby I cannot upload the PowerCMS DB content, It has been working but for some strange reason it doesnt anymore. There have been a few people helping out with this from WA (which I'm thankful for) and the latest resolution is to set up a local DB and then upload the content once completed. I dont have any knowledge of DB's and therefore do not know what I need to do to create the accessable templates for my clients to make changes. I currently have a client that needs a CMS product and I believe it will take some time for me to use the local DB solution.
The PowerCMS software I have purchased does not appear to work, can the problem be taken offline and a workaround solution provided, if not I believe the software is not required.
Your help is greatly apprecited.
Scott
update your existing support incident with this info so that ray can look into it with you.
