Product of the day
Any ideas on how to display a new product of the day each day for the day.
there is not going to be an automated way to do this, it will require some set up on your part.
probably the easiest way is to create a new column in your database to hold the date that a particular product should be the Product of the day.
you will need to set this in the database for each product.
then you can use a reordset to return the product that is set for today:
SELECT * FROM products WHERE DATE_FORMAT(podDate, '%Y-%m-%d') = DATE_FORMAT(now(),'%Y-%m-%d');
