Adding a login box to an index page
Is it possible to add the small login box to an area on an index page? If so, what is the easiest way to achieve this? Looked at the code on the login page and there is lots of it!
just make sure that the text boxes for username, password and the submit button use the same names as the ones on the login page, and set the forms action to submit to the login page and it should be fine.
