Spry.ValidationConfirm ERR
Thread began 12/13/2011 12:27 pm by FrankJay | Last modified 5/04/2012 10:56 am by Jason Byrnes | 2711 views | 16 replies |
FrankJay
I've used security assist to create three presets for one website, namely: administrator, member and customer. I've used the security assist Wizard on all three presets. One in admin root, member root and customer root directories. After running the Wizard I tested all three and had a problem with forget password functionality. In the server behaviours panel I opened SecurityAssist Email Encrypted Password and edited the SMTP server details in the E-Mail Object tab. It now worked correctly.
I then applied templates to all the generated pages. Since then, when testing the forget password functionality, I get the following error for the members and customers. For admin it is working correctly.
Your email address could not be found in our records. Please try again.
Spry.ValidationConfirm ERR: The element Reset_Password_group_Confirm_Spry doesn't
exists!
I have attached the customer and member directories that contain both the original generated files and the ones that are applied to the template. The template file of also attached.
Any ideas how I could correct this error
WA_CustomersLG.zip
WA_Templates.zip
web URL and login details.txt
what version of security assist are you using? I believe this issue was fixed in version 2.0.4.
If you have a previous version installed, please uninstall it form the extension manager before installing the newer version that is available for download from your download center.
FrankJay
Using SecurityAssist 2.0.4
Hi Jason,
I am using SecurityAssist 2.0.4 on a Windows 7 professional platform and using Dreamweaver CS 5.5
steve287725
Same Issue
Hello Jason (and all support of course)
Just purchased Security Assist 2 - really pleased this is a great improvement and money well spent.
I am having the same issue as this however - on my forgot password page I get as the page loads;
The element Reset_Password_group_Confirm_Spry doesn't exists
I am also using a preset for the scheme
Was there ever a firm answer to this one please?
Steve
Massimo
The same Problem
From forgot psw I get this:
Spry.ValidationConfirm ERR: The element Reset_Password_group_Confirm_Spry doesn't exist
Why?
please send a link where i can see the problem to investigate the cause.
Massimo
forgotpassword.php
send a copy of the page please, i think there is a missing if statement that would only include the confirm password spry when the reset form is displayed.
