error coding
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 11292 bytes) in C:\Inetpub\vhosts\bancodotempo.com\httpdocs\WA_DigitalFilePro\HelperPHP.php on line 844
If you setup allows try adding the following line near the top of your PHP page
<?php ini_set('memory_limit','56M'); ?>
You might need to keep increasing a bit depending on what size of file you are uploading
Cheers
Ian
