css menu activation
I am using the currant ccs menu with cs5.5 and each time I logon and go to use the menu extension I have to re-activate the software... This did not happen before... Am I missing something?
Please advise.
Best Torry
Please advise.
Best Torry
Hey Torry,
There are two things that could be causing this problem. One is that you are changing your internet connection between uses; switching wifi networks, or changing from wifi to ethernet or vice versa. The other is that you have activated on more than 2 computers. With our products, each serial number is allowed to be activated on up to 2 computers. Past that, it may function as you are saying.
Please let me know if you are changing network connections, or have more than 2 activated computers.
I didn't realize switching wifi networks caused me the same problem.Yhanks for the suggestion.Its working properly now.
Plate Cutting Machines
